Autoclave cure profile
I am having trouble with a cure profile. Here's what I am trying to achieve.
1. Vacuum level 30" no less than 20"
2. Pressure 85 psi fast as possible
3. Once the pressure reaches 20 psi I need the vacuum to drop to 0 or vent?
4. Temperature rate is 3 degrees F per minute to 355F +/- 10 degrees
5. Dwell time is 6 hours
6. Temperature rate cool down cycle is 3 degrees F per minute
7. Once temperature reaches 150 F I would like the program to stop.
I appreciate anyone helping .
Thank you
David
Thank you
David
RE: Autoclave cure profile
90 psi.
