CJP Weld Spacing
CJP Weld Spacing
CJP Weld Spacing
Are there guidelines on minimum spacing of CJP welds? I'm looking at a submittal of a truss chord 1100 mm deep with two CJP butt weld splices 460 mm apart.
Thanks!
RE: CJP Weld Spacing
What is the difference between a multipass groove weld where the weld beads are fused together and two groove welds that are nearly side by side? There is little to no difference if one is welding low carbon or high strength low alloy steels that have no toughness requirements. Generally, notch toughness is not a concern if the steel framing is enclosed by the building envelop and where the design is not subject to seismic activity or impact loads.
Best regards - Al
Why would they splice a chord twice that close together?
Some one cut it twice and it was still too short?
Best regards - Al
Well, what do you do when you have a truss 81 feet long, and the longest plate you can get is 40 feet? Just saying, it's not always an error by the fabricator.
Thank you all!
