moving icons problem
NX 7.5 and Win-10, high resolution screen
To max graphic area, I move icon by icon into graphic area and then click at X to remove the icon set which i do not need. It were all fine with Win-7. However with Win-10 , whenever I pick the icon-set (e.g standard) and try to move it into graphic area, UG freezes totally.
Is there any trick to clean up the screen from icons?
