Aircraft Ground Flotation Analysis (CBR) S-77-1
Hi Everyone.
I was wondering if there were anybody familiar with the document S-77-1 Procedures for Development of CBR Design Curves. My question revolve around Figure 19 and equation 47 about the thickness / squareroot of footprint area vs CBR/ Equivalent Pressure.
They give the equation 47 to build the curve. The problem is that when I use the equation, I fall very far from the curve.
I thought that there might be a typo in the equation, butit is an old document and I guess they would have flagged it somehow.
The equation I have is: T/squareroot(Ac) = -0.0481-1.562*log(CBR/P)-0.6414*(log(CBR/P))^2-0.4730*(log(CBR/P))^3
Anyone have seen this equation or use it or see a different one?
Thanks.
Thanks.
RE: Aircraft Ground Flotation Analysis (CBR) S-77-1
So whatever the CBR/P ratio is, T/squareroot (Ac) should be the same whatever the aircraft.
But for the sake of the example, we can use KC-135 data for MLG.
Single wheel load: 36 000 lbs
Tire inflation pressure: 155 psi
Tire contact area: 232.3 in2
footprint radius: 8.6 in.
Critical spacing diagonal: 8.14
Critical spacing width: 4.18
Critical spacing length: 6.98
I can't give you any CBR, because the goel is to find the critical CBR for a particular aicraft at different pavement thickness.
what's T ? Ac looks like contact area.
if you're "far off the curve" then one of your numbers is "wrong" ...
maybe your Ac is too small ?
So I used the given equation for multiples values of CBR/P from 0.001 to 1.0 (on a log scale) and calculated the respective values of T/squareroot (Ac). Then I plot those values and I guet a very different curve then what is shown in the reference documents. That is why I was wondering if there was anything missing in the given equation.
Thanks.
SAE AIR 1780 Aircraft Flotation Analysis
SAE AIR 1821 Aircraft Ground Flotation Analysis Methods
"A mile of roadway can take a car a mile. A mile of runway can start an airplane on a journey around the world"
Regards, Wil Taylor
o Trust - But Verify!
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can b
