Clearance Analysis - Clearance Browser Window Problem
Hi All,
I’m having trouble solving one of those little problems that drive you mad!!
I’m using NX9 Clearance Analysis and everything works fine. However, my problem is that the clearance browser will only list the parts as part numbers but it would really make my life easier if I could see part names!
I’ve tried changing the obvious preference in Preferences > Assemblies > DB_PART_NAME but it’s making no difference. However, when a colleague changes this preference he can toggle between part name and number in the clearance browser.
Does anybody know of a customer default that could prevent me from changing to part name in the same way as my colleague? (My customer default is set to show part names)
Cheers,
Paul
