SIF for a threaded pipe connection
I am looking for a more accurate calculation of the SIF for a threaded pipe connection. This will be used an B3.3/.1 stress model.
The code SIF default is 2.3, but this seems high for our connection. We designing a geothermal wellhead with an API buttress thread. The well designers consider this thread to be as strong casing but they do have look at moments from the attached piping.
RE: SIF for a threaded pipe connection
Another great resource for detailed stress analysis is the book by Peng & Peng (just gotta love those author names)
I believe that you should keep in mind that ASME Code SIFs are based on some empirical testing, however ....
They are basically the conservative product of group of engineers at a long and boring meeting
MJCronin
Sr. Process Engineer
