Hole Callout, Hole nog selectable ?
Hi ALL,
I've tried to make a hole callout on the attached .prt. It seems i'm doing something wrong.
I've treid the M6 holes arround the square cutout but i can't select them.
Does anyone have any solution ?
NX10.0.3.5, Windows 7,
Lars.
Lars.
RE: Hole Callout, Hole nog selectable ?
I tried it Inside the model file, on the existing drawing.
Works fine.
I also tried to create a new , separate, drawing , where this model is displayed.
Works fine.
When the view exists on the drawing sheet.:
in the Dimension group on the Home tab. ( I hate the ribbon UI, this description on where and how to find a button...idiotic)
Select the "Radial" dimenssion type, In the dialog change the method from "inferred" to "Hole callout", then select.
Tomas
