Store Front Window Span
I am working on designing some light gage for a college addition. I have a 28 t. tall x 12 ft. wide storefront window. It is surrounded on three sides with CMU. At the top, the Arch/Eor is showing a light gage assembly. i put a note on my shops drawing indicating that I assumed the window is spanning horizontally (why wouldn't it?) The Arch has come back and indicated that it is designed to span vertically. I can't believe this is true and, if it was, would there not be significant deflection compatibility issues at the jambs where it runs next to the CMU?
Thoughts?
Thoughts?
RE: Store Front Window Span
Max height for storefront = 12 ft.
Your spans may be limited by the storefront or curtainwall sections or by the glass. The glass is generally required to meet the requirements of ASTM E1300.
I just finished a system with all operable openings (automatic doors) framed against TSS and light gage framing in a high wind area.
