CODE TO BE USED
CODE TO BE USED
CODE TO BE USED
Dear Gents,
We are constructing a coal-fired power plant, I was assigned for the coal silo/bunker fabrication area and i noticed that
the Vendor Drawings for construction did not specify on what code should be used.
Should this be under AWS D1.1?
Need your advise.
Thank you
RE: CODE TO BE USED
ianmontes,
Despite my own opinion regarding which code to use, your organization needs to identify the relevant fabrication code(s); This is a significant matter, and not a decision you should be making. In any case, consult your engineering group, as this needs to be clearly identified on the drawing and other relevant documents.
RE: CODE TO BE USED
For fabrication, unless specified otherwise, yes.
RE: CODE TO BE USED
D1.1 was used on all five of the new coal fired power plant, coal silos that I have been involved with.
RE: CODE TO BE USED
Thank you very much for your suggestions.
