API 650 - Minimum Number of Rafter and other roof design
Sorry for such title and I appreciate if someone could guide me through this question
I'm still learning to design a API storage tank and one thing messing in my head is roof design. Basically in API 650 only mention the rafter length and not number of rafter, so how do we design on how many rafter is required? Is there any codes and standard mandatory to be followed for storage tank?
I've been searching some tank calculation and some of them said "Minimum number of rafter shall be multiple of 5" others stated 8, 16, 32, and etc.
Thanks in advance
Thanks in advance
RE: API 650 - Minimum Number of Rafter and other roof design
It may be advantageous to use smaller spacing for erection purposes, specifically, to use rafter spacing smaller than the plate width being used. That would depend on erection procedures and past experience.
On a smaller tank, it may be advantageous to make the number of rafters a multiple of 4 or 8 if there are a lot of roof nozzles.
On a larger tank with multiple columns, the number of rafters will be a multiple of the number of outer columns, however many that is.
