Impact test as per UCS 66 ASME Seciton VIII Div. 1
Dear experts,
I am still do not understand the implementation of UCS 66 in ASME Section VIII Division 1.
If our plate material need to be impact tested base on this figure does it mean the steel mill need to perform impact test when they produce the plate ?
or
When we make WPS / PQR we need to include the impact test in our PQR coupon?
or
both ?
Your explanation is highly appreciated.
Syah
or
or
both ?
Syah
RE: Impact test as per UCS 66 ASME Seciton VIII Div. 1
If the material requires impact testing your PQR will most likely need to be CVN tested as well.
