Importing airfoil data, making a curve, and manipulating curve?
Using the following tutorial and the macros that came with CATIA, I was able to import airfoil data points into CATIA from which I created a curve in a sketch. How can I manipulate the curve and scale it.
https://www.youtube.com/watch?v=nP_gErfA5IQ
For example, while preserving the shape, I want to be able to rotate the curve and scale it. However, I can't seem to do that since the curve is fixed to the imported coordinate points. Any tips?
RE: Importing airfoil data, making a curve, and manipulating curve?
Try extracting the curve and then try rotate and scaling it.
For scaling to a specific dimension,you can divide the final dimension by initial dimension to get the ratio.
