Consideration of Slab’s Bending Resistance to the Lateral Load Resistance of a Rigid Frame
Hi Everyone,
I would like to know about your opinion regarding consideration of a slab’s bending resistance (transverse bending stiffness) to the lateral load resistance of a column – beam rigid frame structure…………
In the “Tall Building Structure” – Stafford smith, Alex Coull, it is suggested to ignore the bending stiffness of slab. (5.2.4)
Can you give me anymore references???
According to this philosophy, we are modifying slab bending moment coefficient (m11, m22, m12) to a negligible value (Say 0.01) while modeling a structure in ETABS.
But can you give me any more specific guideline for this???
Thanks in Advance.
Thanks in Advance.
RE: Consideration of Slab’s Bending Resistance to the Lateral Load Resistance of a Rigid Frame
Slab Diaphragm act as membrane in the lateral load path.
In a seismic zone where you're looking to form plastic hinges in the floor framing, you'd need to consider if you then also need to form hinges in the slab as well. Although I suppose that's technically true whether or not we choose to ignore the slab's contribution.
Google slab frames and grossman, they're always writing papers on it.
bookowaski, the thing you describing is known as flat slab frames to me (which also known as flat plate slab frames i guess). But the main problem of that type of structure is the R value (response modification factor for equivalent static analysis of earthquake loading))of the system. for slab frames, the value of R is very questionable because the frame doesn't behaves like a complete intermediate moment frame. so, it is difficult to chose the actual value of R. i have read a paper on it. i will share the link on the next comment......
anybody has anything to add on this view ????
please do share your opinions ..........
Go through the link......and read the paper
Here, in the section 2.2 it is written that:
"The flat plate structure is an undefined seismic resistance system in the design code. If it is
demonstrated that the seismic performance of a flat plate structure is similar to that of the seismic
force–resisting systems defined in the design code, through analytical and experimental study, the
seismic performance factors(response modification factor ( ); system overstrength factor( 0 );
deflection amplification factor ( )) are applicable to design flat plate structure."
do anyone have anything to say about this ?? cause i am searching for more references ........
and we were discussing about "Consideration of Slab’s Bending Resistance". if anyone has found something more about the topic please do share........
Also on important stuff we go through the geotechnical soil spring modeling routine.
