Overlapping Barrel Cam Errors
Hey guys, new to the forum here so forgive me for any nube mistakes. Anyway, I've been trying for a couple days now to model a barrel cam slot into a shaft which overlaps itself and returns back to its origin. I'm not sure of the best way to describe this but it's not just a simple cam slot which moves a cam a short distance, dwells, then moves the cam back, I actually need to move an outer roller(riding on this shaft) a long distance(several revolutions), then turn around and come back. The term for this motion I would describe as an oscillating motion. I've drawn my cam track on a plane tangent to my outer diameter, and wrapped to my desired depth. The weird part is, If I only draw half of my profile it will wrap fine, but when I try the entire path which reverses the direction of the slot, I keep getting intersecting errors. I tried only wrapping half of the profile and mirroring the feature also but again had no luck. Can anybody tell me what the heck I'm doing wrong here? Thanks in advance...Trent
RE: Overlapping Barrel Cam Errors
I haven't looked, but I wouldn't be surprised if you could find a good example of this type of part in 3D ContentCentral.
Be aware that sweeping a profile is not the same as sweeping a solid so you'll need to check your groove for how well the follower fits. I'm not on SWX2016 yet, but I seem to recall in the 2016 rollout session something about the new version having a capability to sweep a solid so you might look into that.
- - -Updraft
