NX advanced simulation XY Plot
Hi all,
I customizing NX advanced simulation (FEM) using NXOpen. I am able to plot the results as XY graph successfully.
But unable to set scale on my own (I dont want the default scale in the XY plot) through code.
Can anyone suggest me best methodology to set user scale values for XY plot in FEM results?
Thanks in advance,
basenxuser
NX 9.0.3.4
RE: NX advanced simulation XY Plot
Your question is pretty advanced, considering you are not only requires the knowledge of CAE template but also NX open. Just a suggestion,have you try to use template to automate your scaling style?
Kind regards,
Tuw
Yes Tuw,
You are right, I should take the approach of templates to achieve it. Thats what I am planning to do. Thanks for your suggestion.
basenxuser
