Linked attributes with UDF
Hello everyone!
I can assign attributes to the objects, and link them to the expressions - that's the common NX functionality. But if I try to do this with UDF, there is a problem. When UDF is inserted into a part, the attribute becomes constant and no longer linked to the original expression. Perhaps it is as designed, but maybe there is a way to make attributes keep linked state in the UDF scenario?
