Components Suppressed by Expressions not displaying
I have an assembly where I have some sub assemblies that are suppressed/unsuppressed depending on the value of an expression. When I unsuppress one of the sub-assemblies it becomes active again, but the components are not visible on screen. I have to go into the assembly navigator and select the check box next to the particular component. Unhide all does not seem to work either.
Has anyone else seen anything like this or has a suggestion on what I could do to not have to go to the assembly navigator to get the components to display?
This is NX9.0.3.4
RE: Components Suppressed by Expressions not displaying
When the Suppress By Expression is created, it may help to have the subassembly expanded and make sure the components within the subassembly are highlighted as well as the top level of the subassembly.
Also there may be something within your load options that need some adjustment.
