Converting simple models from Abaqus to Ansys format
Is there a 3rd party (preferably freeware) program that will convert simple models from Abaqus to Ansys format & vice versa?
I dont really want to reinvent the wheel but if I have to then I have to.
I dont have an Ansys license but one the pieces of software I am using will only deal with Ansys models.
Nic
RE: Converting simple models from Abaqus to Ansys format
If you have an ABAQUS licence, it comes with converters usually called aba2ans or similar.
Nic: I do not know if there is a free utility out there. If the model is simple, then translator utilities that come with solvers should be good enough. I know Abaqus has one such utility, as bkal mentioned above. If you have access to HyperMesh, then it will allow you to perform the translation.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
This kind of code was actually compiled by some guys in Nastran forum. Here:
http://www.eng-tips.com/viewthread.cfm?qid=401488
Spaceship!!
Aerospace Engineer, M.Sc. / Aircraft Stress Engineer with 7 years of experience
(United States)
Thanks for the pointers, I have no idea why I didnt try Abaqus's in built translators, too close to the problem I guess.
@aerostress82: I tried their converter & have posted on that thread the results (it didnt work) thanks for the link.
Nic
What do you mean "flat"?
flat input deck = no part or assembly definitions
Before you write your input file in CAE go to Model -> Edit Attributes and check the box that says "Do not use parts/assemblies in input files"
