Wartsila W34 motor engine exhaust gas temperature sensor
Hi dear friends
I would like to know the type of Wartsila W34 motor engine exhaust gas temperature sensors. And where i can find the data sheet of this sensor. I would appreciate in advance.
thanks a lot
RE: Wartsila W34 motor engine exhaust gas temperature sensor
Hello everybody:
Why don't you ask the supplier of that engine or directly to Wärtsila? Here is a link to start your search www.wartsila.com/services/support/technical-suppor...
El que no puede andar, se sienta.
I am not sure about the Wartsila W34.But the Wartsila W32 exh gas sensor is type k NiCrNi 0-600C
