Assembly structure load order
Hello All,
When I have a large assembly build up out of sub-assemblies, in which order is NX loading the assembly? Is it the sequence in which the sub-assemblies have been added? Is it possible to re-order this?
Will this be of influence on any (wave)links used between these sub-assemblies?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
RE: Assembly structure load order
So, If we are lucky, somebody will reply, Else you ask GTAC, and report back here
- We have the problem that our assembly structures ( very large) sometimes contain different revisions of the same item, stored in TC, we run Precise, and NX seems to load the revision which is encountered first. Which then if all parts are saved might replace a newer revision with an old. - We only allow NX to use one rev.
Tomas
