Ansys Workbench: Same Meshing on repetitive Components...also in other projects...copy mesh
Hey,
I have a structure that is build out of identitical blocks, I did not find a way to mesh all those blocks identically with a (more advanced then swept) mesh. Is there a way to copy a mesh or to always get the same mesh on a certain body (e.g. with a command snipet)?
I'm very grateful for your help!
Johannes
RE: Ansys Workbench: Same Meshing on repetitive Components...also in other projects...copy mesh
There is no way to copy mesh from one model to other except that you duplicate the mesh sizing and method of one model and then change the SCOPING GEOMETRY to the new geometry. Writing a command snippet is possible but you'd better spend some time and do the meshing as you only need to perform the meshing once and it's not a repetitive action during solution.
http://ansys24.ir
Solving engineering problems with ANSYS
