femap error message "curve xxx has no facets"
My femap model got error message "curve xxx has no facets", my whole model surface gone, any body can help?
Liulh
Liulh
RE: femap error message "curve xxx has no facets"
Simply delete those corrupted surfaces and do a file > rebuild to see if the "no facets" message appears again....
Also use GEOMETRY > SOLID > CLEANUP of your model.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
I did rebuilt the result shows "ok to delete unreferenced solid geometry? your model constrains invalid geometry that can not be used" I choose ok, then all the surfaces gone. the file has been attached, can you help to take a look.
Lihua
