Import 3D from dwg file in NX8.5
When I try to import the following file in NX8.5
I have got only 2 notes
Is it possible to obtain the 3D or is it a limitation in our dwg translator ?
I know that the 3D is inside because I was able to open the file in autocad then export an iges ==> and import in NX
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.fr
Thanks in advance
Didier Psaltopoulos
RE: Import 3D from dwg file in NX8.5
Independent of your situation above, DXF is always last on my list of neutral files that I'd want to have sent to me - DXF is or at least was limited with the spline complexity it could support. Something to the effect that anything higher than 3 degree wasn't supported.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Thanks for your answer. I agree with you.
But my customer have not access to AUTOCAD and have a sample AUTOCAD assembly to import in NX. He has no way to obtain STEP, IGES or PARASOLID files, only dwg
Didier Psaltopoulos
Tim Flater
NX Designer
In fact another customer (with NX and AUTOCAD) have helped me for the test
Didier Psaltopoulos
Glad to hear you have a workaround - was being facetious in my last response.
Tim Flater
NX Designer
And the problem is that the Autocad step translator is an addon to autocad, and this company has not bought it, so they expect you to take care of their translation problem.
I'm getting tired of this.
I feel like Don Quijote, fighting windmills in belief that they are giants... No matter how hard i fight, i just can't win.
Tomas
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
