add multiple elements to multiple groups automatically
Is there a way to automatically add/remove multiple elements from multiple groups automatically, instead of having to go into each group, using the group > elements command and doing it that way?
your help is much appreciated.
RE: add multiple elements to multiple groups automatically
Not that I know of. I wrote this API a while back to do just that, but never found the functionnality that useful so I didnt push further...
AP
Sub Main
Dim App As femap.model
Set App = feFemap()
Dim l1 As Long
Dim grSet As femap.Set, gr As femap.Group
Set grSet = App.feSet
Set gr = App.feGroup
Dim set1 As femap.Set, set2 As femap.Set
Set set1 = App.feSet
Set set2 = App.feSet
If grSet.SelectMultiID(FT_GROUP,1,"Select Groups") = FE_CANCEL Then End
'could detect if multi mode is used and directly select groups on screen...
'could add possibility to chose between elems and nodes... => write an HMI
l1 = App.feAppMessageBox(3,"Press 'Yes' to add elements, 'No' to remove, 'Cancel' to quit")
If l1 = FE_CANCEL Then End
If set1.Select(FT_ELEM,False,"Select elements to remove") = FE_CANCEL Then End
While gr.NextInSet(grSet.ID)
set2.Clear
set2.AddGroup(FT_ELEM,gr.ID)
If l1 = FE_OK Then set2.AddSet(set1.ID) _
Else set2.RemoveSet(set1.ID)
gr.RangeDeleteAll(FGD_ELEM_ID)
gr.SetAdd(FT_ELEM,set2.ID)
gr.Put(gr.ID)
Wend
App.feViewRegenerate(0)
End Sub
