Behavior of floating structure
Hello All
My goal is to improve the floating stability of the following structure(attached JPG) my biggest problem is to calculate it's "center of rotation"
The structure is 90% submerged, It's floating center is higher the the mass center there for it is מaturally stable, now the question is should i consider it's C.M as the rotation axis?
or should i go and calculate its metacenter because it is not fully submerged.
Thanks all
Jenia.
Thanks all
Jenia.
RE: Behavior of floating structure
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
BUGGAR, the metacenter need to be found even if the body is netural stable (F.C higher then the C.M)?
TTFN
TTFN
I need to design the right size floats and it's distance from the center of the structure to overcome the weight of the licked water and maintain economical
solution
TTFN
my only problem is to understand if the mass center or metacenter are the rotation point of the structure, the moment i will be able to find the rotation point is the moment i will be able to creat a free body diagram from this point it is simple mechanical engineering.
Do you think i need treat the metacenter as the rotation point of the hole system?
