FORTRAN: condition on array elements in one column changes corresponding elements in other column
Hello all,
although it might sound trivial to more experienced users, I am trying to create a code in FORTRAN (preferably f90 or higher) of a n series x 2 columns matrix, where a condition on some elements of column 1, will change the corresponding elements of column 2 (i.e. only those that have the same "i" with the elements affected by the condition). So far I have managed to do this by creating two (2) column arrays containing the elements and by using a simple "where" command I did what I wanted. Could someone please try to inform me how to perform the same job but without spliting the array into two sub-arrays?
Working example code of what I did follows:
Thank you in advance for your kind assistance.
CODE --> fortran
program test
implicit none
integer::elem
real,dimension(:),allocatable::A
real,dimension(:),allocatable::B
integer::i,j
elem = 10
allocate(A(elem))
allocate(B(elem))
do i=1,10
A(i)=i
end do
do j=1,10
B(j)=0
end do
where (A>=3 .and. A<=6) B = 1
deallocate(A,B)
end program test Thank you in advance for your kind assistance.
RE: FORTRAN: condition on array elements in one column changes corresponding elements in other column
do blah
A=i
if A>=3 .and. A<=6 then
B=1
else
B=0
end if
end do
FWIW there is a Fortran forum: forum545: Fortran
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
CODE --> f95
