Modeling Defaults/ Standards for Holes
I'm trying to set the default Tip Angle to be 140°
For General Hole, it's set by the Customer Default.
For Threaded Hole, it's set in ...\Standards\nx502_Threaded_Hole_Standard.xml
I'm sure it's pretty obvious, but I can't find where to set the Tip Angle for Drill Size Hole and Screw Clearance Hole.
Can anyone help ?
NX 9.0.3.4
NX 10.0.3.5 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: Modeling Defaults/ Standards for Holes
Check the "nx6_Drill_Size_Hole_Standard.xml"
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Nutace,
Neither nx6_Drill_Size_Hole_Standard.xml or nx502_Screw_Clearance_Hole_Standard.xml make any reference to the Tip Angle.
That's where I was hoping to find the setting,
NX 9.0.3.4
I contacted GTAC...
There is an existing enhancement request for the customer default for tip angle to be extended to the other hole types (ER 7386209).
I added my name to it,
NX 9.0.3.4
