Slab on Grade
Slab on Grade
Slab on Grade
I have never designed slab on grade. The loading i have is HS 20. I don't have soil information also so assuming good soil with sub grade modulus of 200. Please help.
RE: Slab on Grade
This is essentially a rigid pavement. Use PCA or AASHTO rigid pavement design procedures. Your assumed sg modulus is probably a bit high if you don't know soil conditions.
