NX Drafting Section Label A1-A2 possible?
Hello All,
Based on figure above, is it possible to create a section label in NX as "A1 - A2"?
Kind regards,
Tuw
RE: NX Drafting Section Label A1-A2 possible?
I am pretty sure they have to be the same name. If you want some associativity then you can name it section A. Then for the letter near the section line you can associate a note with the number "1" or "2" next to it. Therefore when the view moves, the numbers move with it. Then in the actual section view you can double click on the label and edit the text to add the "1" and "2" for example "SECTION <C1.4000><WRef1*0@VWLETTER>1-<WRef1*0@VWLETTER>2<C>"
