Shape function gradients with 3D boudary elements
Hello all,
I am developing a 3D boundary element program where I have only surface elements (4-node quads and 3-node tris), but that are oriented in 3D space. Likewise, I want to compute x,y,z gradients on each of these faces.
I have a nodal solution (phi), and I want to compute dphi/dx, dphi/dy, dphi/dz.
I have successfully done this for quads, but cannot seem to figure it out for triangles.
For the quad-4 with linear shape functions:
N = [1/4*(1+xi)*(1+eta) 1/4(1+xi)*(1-eta) 1/4(1-xi)*(1-eta) 1/4(1-xi)*(1-eta)]
I can compute the differential operators in x,y,z (dNdx, dNdy, and dNdz) by simply computing 2 tangential vectors (dxdxi, dxdeta, dydxi, dydeta, dzdxi, dzdeta):
e1 = dNdxi*[ex,ey,ez]
and
e2 = dNdeta*[ex,ey,ez]
Taking the cross product of these gives me my surface gradient:
e3 = cross(e1,e2)
Then using these 3 vectors as my jacobian:
Jac = [e1; e2; e3];
I can invert my jacobian to compute dxidx,dxidy,dxidz, detadx,detady,detadz, and finally post multiply with dNdxi and dNdeta again to compute dNdx, dNdy, dNdz:
dNdx = Jac(1,1)^-1*dNdxi + Jac(1,2)^-1*dNdeta
dNdy = Jac(2,1)^-1*dNdxi + Jac(2,2)^-1*dNdeta
dNdz = Jac(3,1)^-1*dNdxi + Jac(3,2)^-1*dNdeta
These work well, and I get the correct gradients.
But now for the 3-node triangle, it's not so straight forward. I have formulated the TRI-3 with 3 local coordinates (xi, eta, and zeta), where my shape functions are just:
N = [xi eta zeta],
and so:
dN = I (identity).
How can I compute dNdx, dNdy, and dNdz for the linear 3-node triangle?
Any help is appreciated, and thank you in advance.
RE: Shape function gradients with 3D boudary elements
Being not so familiar with Gauss Quadrature in the last 10 years, I found this which also has some directions for a triangle. Not sure if it is explained there but it feels like you are entering a world of pain :) Good luck!
http://math2.uncc.edu/~shaodeng/TEACHING/math5172/...
Please let me know if you find the solution later, I would be very interested as well..
Spaceship!!
Aerospace Engineer, M.Sc. / Aircraft Stress Engineer with 7 years of experience
(United States)
hi aerostress82, the issue I am talking about is not Guass Quadrature. Although, if I were to integrate my gradient (which I am talking about) over the element, I would use Gauss Quadrature.
The issue I am referring to is computing the discrete exterior gradient on the element face (in 3D, 3 components). Since it's oriented in 3D space, standard 2D formulations do not apply, and since it's a boundary element, standard 3D volume formulations also do not apply.
Sort of tricky, and cannot seem to get the correct derivation, and cannot find anything online about it; though I know somebody has at least attempted it before.
Thanks for the clarification jfieldstone. I'm not familiar with boundary element method but the quad-4 equation looked very similar to finite element - that's why I sent that link.
Maybe if you happen to have some research assistant friend(s) in university, you could send him/her the sciencedirect links related to your case? (after checking them from sciencedirect)
Other than that, hope someone can help you on this. Good luck with it!
Spaceship!!
