Laboratory for Hydrocarbons design
My issued is the following:
The hydrocarbons that we are going to handle are Gasoline, Diesel and LPG.
The tests to apply to these hydrocarbons are to determine la quality of the product.
In these areas where the samples are storage, handle, prepare, etc. Is need it a air conditioning system. this unit need to be a 100% air fresh or a simple Air contioning handling unit. I know that I need to have Fume hoods, Is this system (Fume hood exhaust)independient of the air contiotioning system,
My worried is because I need a negative pressure in these areas due to avoid flammable gases go to non-laboratory areas (What is the desing pressure in this case where I can get the value of that negative pressure in a standard).
It is necesarry to have fire-smoke dampers in this desing.
What are the conditions of temperature, pressure, humidity, etc, that I need in these kind of laboratory. There is a table in a standard or what?
Please I need some much your help.
RE: Laboratory for Hydrocarbons design
To get a negative pressure you have to make sure that exhaust air flow rate is higher than the supply flow rate.
I would also recommend blast dampers if applicable (unless the lab is not in the periphery of the building)
Fire dampers or fire and gas dampers or fire and smoke dampers are used to isolate a room from fire/smoke/gas. I would recommend motorized dampers rated for Zone 1 in your case.
As for humidity, it depends whether it is an electrical or a server room or for human occupancy (also available in ASHRAE)
For design conditions you can refer to ASHRAE 90.1 and 90.2
Smoke damper is required at smoke barrier and corridors with smoke and draft control with some exceptions
Fire/smoke dampers are required at shaft enclosures/horizontal assemblies with exceptions
Fire dampers are required at fire walls, fire barriers and fire partitions with exceptions
a fire damper and a smoke damper can be used in series to make up for a fire/smoke damper.
Hope this was helpful.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Attached may be a useful reference
http://www.wbdg.org/ccb/DOD/UFC/ufc_3_460_01.pdf
