Sketch Fillet Method Untrim - constraint point on curve is missing
In Sketch
When I use the Fillet Method Untrim. The constraint point on curve is missing.
In NX6 I would get tangent constraints and point on curve. Now in NX85 I just get the tangent constraints.
Is there some fix for this?
I am using NX 8.5.3.3 MP10
RE: Sketch Fillet Method Untrim - constraint point on curve is missing
It works fine for me using NX 8.5.3.3. Have you checked to make sure that the 'Inferred Constraints and Dimensions' options are set to include the automatic creation of 'Point on Curve' constraints?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
That was it. I had "Inferred Constraints and Dimensions' option 'Point on Curve' turned off.
I turned it on and it works like I want. Thanks!
