Distance protection relay - Reference temperature cable impedances
Hello all
I need to parameterize a distance protection relay based on measurements of cable synchronous and zero sequence impedances on a 50 kV line.
However I am in doubt about the reference temperature to be used for the resistance values. We have measured them at 3°C, but I can´t find anything about requirements to which temperature the results are to be corrected. Are anything stated in the standards or manuals for distance protection relays and in case where ?
Best Regards
Hans-Henrik.
Best Regards
Hans-Henrik.
RE: Distance protection relay - Reference temperature cable impedances
Try Anderson's Analysis of Faulted Power Systems.
Thank you very much for the answer. Are you able to make reference to an IEC, EN, etc. standard about the temperatures.
Best Regards
Hans-Henrik
