Open Delta Voltage Regulator
Is anyone aware of how I can model an open delta voltage regulator on a model which only accepts three phase units?
In particular the issue with the tapping being on the series winding?
Should I model it as an auto transformer or as a regular transformer?
RE: Open Delta Voltage Regulator
It is not recommended to connect line to neutral loads past an open delta voltage adjuster. Past the open delta auto-transformer the voltages to the neutral are no longer equal.(The open delta auto-transformer connection is often used for voltage adjustment. A common application is between 480 Volts and 600 Volts. This comes up a lot in Canada for temporary power at industrial sites. The majority of rental generators are 480 Volts and many industrial sites in Canada use 600 Volts.)
Bill
"Why not the best?"
Jimmy Carter
