measurement in ansys
hi,
Do we have any option for measurements for model in ansys and to select mid point or any node at a specified distance
RE: measurement in ansys
In ansys design modeler you can use ruler for measurements, also you can select midpoint in constraints menu when sketching in design modeler, first select the point and then the line to put the point on the midpoint of line. It is also possible to select nodes and elements in ansys mechanical but turning one select mesh option.
http://ansys24.ir
Solving engineering problems with ANSYS
