VAV maximum and minimum airflow setting
A space require supply air of 500l/s and its outdoor air requirement is 450l/s. If a VAV box is used for this space then maximum supply air setting of a VAV box is 500l/s and minimum airflow is set at 450l/s. How good is it to provide a VAV box with electric reheat coils in this case? The minimum airflow required to energize electric reheat coil is 450l/s in this case which is very close to 500l/s. please advice.
RE: VAV maximum and minimum airflow setting
MIN = 450 l/s = 950 CFM
You may have a high occupancy space? If so, add CO2 control. Then lower VAV MIN to meet heating load, or as low as 1/3 box max, whichever is greater.
knowledge is power
typically we add zonal motion sensor to bring the zones in a "standby" with wider deadband and no minimum flow. Because you can't predict when people leave their office, meeting room or come in later.
how would your control work in case VAV in minimum and your space does not need heating.?
