Sensing Moist objects
We want to monitor an "assembly line" situation where we have solid, porous objects coming down the line, somewhat equally spaced, running at about 4 feet/second. Any optical sensor can watch for a missing piece, but some of the pieces did not get wet like they should. Anyone aware of a noncontact sensor that can tell us when a dry one goes by? Capacitance will work, but we'd like to keep the sensor a few inches from the objects if possible, rather than just millimeters. What we need is a longer range sensor that we can calibrate for air, wet object, dry object.
Any ideas? Thanks!
Any ideas? Thanks!
RE: Sensing Moist objects
1. To establish best theory and best method
2. To develop the sensor or search for the existing ones
One may start by trying:
http://www.thomasregister.com
type Capacitive Sensor, which will return
Sensors: Capacitive; 54 Companies with their direct contacts and offerings,
Make an inquiry over
jlcusa@jlcinternational.com
Check whether TRIME-TDR technique could work at
http://www.alive.de/IMKO/Trime-compare.htm
Meanwhile, if you come across some thing that looks good, let me know!
2 if cost is not an issue then there are specialist moisture analysers ($1k-5k +)
talk to lab / process instrument companies. Most of these use a reflected light source and sample shutter type system & have a range of about 100 -300 mm
If you are further interested I will rat thru my boxes and find some brand names I have worked on. PS calibration of moisture is the biggest pain in the A*** going.
Does the weight vary with moisture?
Believe me you my be better looking for some constistant property change rather than moisture.
try putting the cap probe under the transport sytem with a window or hole
Regards Don
If the object is shiny when it is wet, you could use a calibrated light source and a light sensor. With this you measure the reflective difference. It probably doesn't even have to be that different. Opto sensors can be very sensitive.
