Supply airflow Air changes
Hi everyone. I have a question regarding Air changes in occupied space. I am very much clear on Ashrae 62.1 Outdoor air requirements. My concern is about the total supply air changes that is to be maintained in any space. For example: A room has outdoor air requirement of 210 l/s following Ashrae. The total supply air required as per calculations is 270 l/s. The air changes obtained for 270 l/s is around 4.5ACH. Is there any requirement to maintain minimum ACH for supply air? If not then why most of the time we take 1cfm/sq.ft (5 l/s/sq.m) as minimum supply airflow rate in many applications.
RE: Supply airflow Air changes
knowledge is power
