Bicycle Fluid Trainer Question
A bicycle fluid trainer works with the bicycle tire turning a rotor in a sealed chamber of oil.
I'm trying to calculate pressure rating of the seals based on the following inputs.
There is some air in the chamber to allow for oil expansion and I know the cold temperature and oil volume, so I can calculate the change in volume of the oil base on the hot temperature which can get up to 250 degrees F in extreme testing on the test stand.
So the air is compressed by the oil expansion and its heating up. I cant use the ideal gas law because air at 250 F is not a ideal gas.
What do I use?
Thanks!
What do I use?
Thanks!
RE: Bicycle Fluid Trainer Question
Read this and return here if you don't understand how to do it.
https://en.wikipedia.org/wiki/Compressibility_fact...
Say the initial conditions are:
Temperate= 291 K
Pressure= .1 mPa (atmosphere)
Air Volume= 45 ml
Final conditions:
System heated to 374 K
Oil expands and compresses air volume to 35 ml
What is the pressure?
Also, there is no mansion of humid air, which I think would play a large role.
It does say that the ideal gas law is probably a good approximation below 2 atm, I think I am below 2 atm, so ideal gas law it is?
Calculate the pressure using the reduced gas volume due to the expanded oil volume and also assuming the gas has reached the oil's temperature. Then using the ideal gas equation, calculate the pressure. If both assumed and calculated pressures are nearly equal, the pressure value you assumed was a good one. Leave it at that, or do another iteration.
Your gas is probably in contact with oil, not water, so if anything it has oil vapor in it, not water. Worry about that later. If you have a gas mixed with other vapors, compressibility becomes much more complicated. Hire a chem E if the answer is that critical.
