Vertical Wind Turbine, Electro-magnetic Clucth
Hi there, we are designing Vertical Axis Wind Turbine.
The issue is that it would not self-start, unless it has a “zero” resistance. It is ok with a bearings, but it is not ok with a Permanent Magnet Generator, since magnets would have initial resistance / torque when starting from zero RPM. Consequently there is a need to disengaged generator from a wind rotor, by using electro-magnetic clutch (we have salvaged it from a car air /conditioner compressor).
So here is a question : “How to activate an electro-magnetic clutch, (engaging wind rotor to a generator on a Vertical Axis Wind Turbine), by a tachometer, when rotor reaches the region of 200 RPM?”
Thanks a lot
Eugene Mak
RE: Vertical Wind Turbine, Electro-magnetic Clucth
Use a tachometer with a relay output or use a speed switch in addition to the tachometer.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
