Drafting sheet title block not loading a variable.
Hello all.
After TCe 10 and NX 9 upgrade, we are facing a issue on drawings title blocks.
As probably many companies our title blocks retrieve information from TCe data forms.
But one of theses fields are not retrieving this information on drawing load. The field only shows the information after save on NX. Every time we open a drawing, even without need to change it, we have to save it again to title block retrieve that field information.
What is going on this? Any ideas?
Thanks.
Thanks.
Gerson Fioravanti Junior
Mechanical Production Engineer
RE: Drafting sheet title block not loading a variable.
Problem solved when we changed the variable name to other one.
The old one was conflicting with something in NX9.
The odds of doing this is that we will need to change all drawings title blocks.
