axisymmetric filament wound shell
i have model an axisymmetirc fw shell, in patran and using Nastran as a solver, i used the ctriax6 element.The problem is how to define the material properties. I know the angle which the fiber made with the meridian of the shell, but the material property form required E11,E22,E33,NU12,NU23,NU31 and G13. I know the Ef, Et, Vft and Gft.
Q1-Do i need to calculate the E11,E22,E33,NU12,NU23,N31 and G31 for each element seperately, based on the angle which it make with the meridian. or E11=Ef E22=Et etc.
Q2-if yes, than what is the THE value present in CTRIAX6 entry shows?
Q3-Does any body has a sample code for this type of shell.
Amir
Amir
RE: axisymmetric filament wound shell
Typically, you specify the properties of a single lamina - the data you happen to have; and then you define the laminate structure - angles of the layers. The program does the rest.
I hope that this helps....
