High Pressure Pilot operate pressure reduce valve.
Hi Guys,
I looking for HP Pilot operate pressure reduce valve.
o Operating Pressure: 0-5000 psi
o Operated Flow rate: 20.9 m3/hr.
Unfortunately, all supplier return with their PRV only can work for 500psi...
Did you guys encounter any HP PRV? Myself actually never bought PRV working in so high Pressure.
I guest we are I in the wrong direction, maybe should reply with Control valve.
BR
Michael
RE: High Pressure Pilot operate pressure reduce valve.
Don't know if this is gas or liquid, but this is more like a choke valve specification. Look up choke valves instead or "Pressure Reducing valves". I'm surprised the vendors don't have this in their range of control valves.
Can you post a link to what you mean by "Pressure reduce valve"
It will be some sort of multi hole plug and cage device.
Something more like this https://www.allergycosmos.co.uk/blog/positive-nega...
