Shortcut Toolbar disapairs when move the cursor the "wrong" way
Hi
If I click on two curves in Sketch the Shortcut Toolbar shows up with constraint options.
If I move my cursor the "wrong" way the Shortcut toolbar.
Is there a way I can make the Shortcut Toolbar show up again without un-selecting the curves and reselecting the curves?
I'm using NX8.5
I'm using NX8.5
RE: Shortcut Toolbar disapairs when move the cursor the "wrong" way
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
The fact that that the Shortcut Toolbar disappears IS the intended behavior since we knew users would not like it if it stayed on the screen and people had to work around it, and I would guess that the idea was that if someone needed to see it again that the highlight and MB3 steps were seen as a reasonable action to take. But if you want to call GTAC, go ahead.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks, that is the answer I needed.
By the way, my number 1 way of working is to use the radial tool bars. I think I saw the radial toolbars in NX3 but I did not start using them till NX6.
Now that I understand how to bring back the Shortcut Toolbar I hope to get in the habit of using the Shortcut TBs.
I'm not sure if modeling Shortcut TBs are like that with, say, preselecting an edge and having Edge Blend always show up regardless of edge type or ID.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
