STRESS CONCENTRATION FACTOR, SHORT CHAMFER IN EDGE OF CIRCULAR APERTURE
Fellow Stress Engineers:
Do any of you know of a reference to a stress concentration factor in-way-of a chamfer over a small proportion of the circumference of a circular aperture; see attached view.
Thanks in anticipation.
StressMan
StressMan
RE: STRESS CONCENTRATION FACTOR, SHORT CHAMFER IN EDGE OF CIRCULAR APERTURE
- If you do not have the loads or cyclic loading - than this is a good time to get acquainted with the OEM.
- For an added margin of safety - the blended location will have to be NDT crack checked; roto-peened & corrosion-resistance treated.
* Wing plank damage around cut-outs is regarded as significant damage - regardless how small the defect.
is a 3rd edition that I don't have since being retired for quite some time.
R. Roark's "Formulas for Stress and Strain" has some tables for concentration factors... not very complete.
G-pa Dave
The blend is at a systems penetration in a wing rib. To design, fatigue life is very high. Treating the blend as a chamfer around the entire circumference and calculating an effective plain hole diameter leads to a stress increase at the attachment holes - no problem. I am left however, with what to do at the blend. edmeister's reply indicates that it is not trivial.
StressMan
Considering the following case: 1) A hole in a plate 2) A notch at the edge of the hole
Stress concentration for each calculated separately.
1) Hole - Kt of 3
2) Notch - Kt of 2
Stress concentration superposition (assuming the notch is located at peak kt location of the hole - normal to loading direction)
Total kt = Hole kt x notch kt = 3 x 2 = 6 (Stress raises too much!)
For this case, chamfer can be assumed as notch, since chamfer is extended to the most of the thickness.
You might get somewhere if you consider the problem similar to a hole with a bump, and assume the Kt increases by the same ratio ... Kt = Kt_cut-out*Kt_circle_with_bump/Kt_circle
http://espace.library.uq.edu.au/view/UQ:131820/A1....
StressMan
