Gas Injection - JT Cooling Issue
We have a producing field with a single gas injector. Right now we are injecting into a pool with a reservoir pressure of ~23MPa. We're considering adding an injector in an adjacent pool, but the reservoir pressure is ~13MPa. As the two gas injection wells will be sharing a single gas injection system and will be drilled out of the same drill center, the second injector will experience a significant dP across the injection choke at any rate due to the line pressure being maintained to inject into the first well.
This dP results in WHTs dropping to as low as -15°C. Our problem is that the downhole equipment is not rated for these temperatures (minimum geothermal warming occurs at the rates we are interested in). Our vendors are suggesting that we spend $100k's in order to qualify the equipment, but there must be a better solution. Any experience with such an issue out there? We can't be the first to inject into two different pressured pools.
Also, I realize that a DH choke could take the brunt of the dT within the reservoir and away from equipment, but if we're considering a dual zone well with active DH valves this may still be a problem. Any thoughts?
RE: Gas Injection - JT Cooling Issue
Depends on the ambient temperature, flow rate and how high the temperature needs to get to to avoid any issues. You might get enough heat energy from the air or you might need extra heat.
Either that or run the joint system at ~13Mpa and then add another compressor to get up to your 23Mpa.
Lots of ways to skin this cat.
Ambient temperature is one of the drivers of the problem. Sea floor is at -2C
Another option would be to take the dP in 2-4 stages using progressively smaller choke nipples.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
2. What temperature is the "downhole equipment" rated for?
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
