Macro measure between Product and Point
Can someone help me which function I need to use for Measuring distance between Product and Point.
RE: Macro measure between Product and Point
I can get distance between points, edge etc. Can I use Product in the same fashion?
Here is what I was trying, there are three (or more) Products or Components in an assembly. A line passes thru all of these. I need to sort these Products in the increasing order of their distances from start point of line. Any ideas?
order the measures. sort the product...
the difficulty is in the product as the intersect won't let you have the product as an operand, so you will have to loop through all solid from all parts of the product... Fun in perspective.
Post you code, I will follow and help you at each steps.
define sort?
just know which one is closer to the point or actually change the order to the assembly element according to the distance?
We are not modifying assembly, it is just reporting the Products' Sequence.
