isolator in a waveguide
can someone detail the function of an isolator in a waveguide assembly as it relates to eliminating reflected power
RE: isolator in a waveguide
Sort answer:
It's a circulator with a load on the 3rd port. Xmitter power goes to antenna, reflections go to load, not much goes from the load to the Xmitter.
Long answer:
http://www.g1sle.com/files/downloads/circulator.pd...
Especially around section 7.3 on page 23.
Thank You Very Much!!!
