Steel Design problem, columns red, no error msg, ratio<1
Hi gents,
I am presently working on a 7 story building using CSA S16-09. LFRS is a mix of Moderately ductile moment-resisting frames and Moderately ductile concentrically braced frames. When I apply steel design, some of the columns are red,even if the stress ratio is less than 1 and no error message is showing. Most of them are on the corners and on the last floor. Project file is attached. Etabs V9.5.
Anyone encountered this problem before?
EDIT: ETABS indicate BCC failure (beam column capacity ratio and can be fixed by changing beam section for a weaker beam or a column by a stronger column.
FIXED
FIXED
