Cantilever Beam FE
Cantilever Beam FE
Hi
I've been trying for some time to develop a FE model using Mathcad that will use a variable stiffness matrix. I have written a basic FE calculation that provides me with values that correlate well with the classical approach; however, ideally I want to be able to update the beam bending stiffness depending on the calculated curvatures ie the beam gets stiffer as a certain beam curvature is achieved. Non linear I guess.
If anyone has any ideas, or has came across anything like this before, your input would be much appreciated. Thanks
RE: Cantilever Beam FE
There are some things on the PTC Mathcad website that might help:
https://support.ptc.com/appserver/cs/view/solution...
https://www.ptcusercommunity.com/docs/DOC-3696
http://support.ptc.com/WCMS/files/128766/en/ptc_me...
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
